My Project!!! needs a lil jet setting love from you guys :)
Discussion in 'The Workshop' started by Paradox, Sep 12, 2008.
  1. Paradox
    Paradox New Member
    (JET QUESTION AT BOTTOM OF PAGE !)
    hay peeps im brand new here
    had a old typhoon 125cc sitting in my shed
    IM GOING TO NEED SOME JET HELP OK PEEPS...SO PLEASE READ THROUGH
    ILL ALSO ADD PICS IN A SEC
    anyway last month i got it out as it was bought for hella cheap last year,
    needed alot of T.L.C!
    anyway i dnt know hardly anything about scooters but thought
    ill just take the lot to bites and look for problems on the way....
    so i go to buy a haynes manual as i think i better use touque settings where i can :)
    anyway..Long story short i took everything to bites everything seemed very good for 1996 typhoon..JUST LOADS OF SHIT ON THE STATOR/ALTERNATOR AND STICKS EVERYWHERE..crank good..carb good ..gears..variator..rollers etc
    (just wish i took camera pics before i stripped everything as omg the carb float needle i didnt know if i put bk properly and putting all those cables and the wireing loom bk WHAT A PAIN IN THE FOOKING ASS
    pics i took after..errrrrrrr bad as camera phone
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    OK NOW TIME FOR WHAT IVE DONE!! :D
    AND WHAT IM HOPEING TO DO (WITH A LIL OF YOUR HELP!! :punk: )
    (WHATS BEEN DONE)
    1.NEW REAR HUB BEARING BEHIND GEARS
    2.CLEANED PISTON..SHOULD OF CHANGES RINGS WHILST I WAS AT IT OOPS
    3.NEW BEARINGS IN FRONT WHEEL
    4.NEW ENGINE MOUNT BUSHES
    5.COMPLETELY TREATED FRAME
    6.CHANGED EVERY PETROL HOSE ETC
    7.RESPRAYING PANELS IN PROCESS (DNT KNOW WHY ALOT HAVE LIL CRACKS AND LUGS MISSING BUT WE SHALL SEE THE END PROCESS PICS SOON IF YOU WNT?
    8... i forgot i wired up a talking alarm/imob...to easy to steal these things(screw and clawhammer trick comes to mind lol)
    THIS IS THE IMPORTANT PART EVERYONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! READ BELOW
    WHAT IM GOING TO DO & BUY WITH YOUR HELP PLEASE!!!! (PULLING MY HAIR OUT NOW!) PLEASE ALSO COMMENT ON IF THE PRICES ARE OK OR TOO MUCH...THANKS
    1.CHANGE MY FRONT FORKS WITH DOPPLER HSM'S (WHAT YOU LOT THINK? OR SHOULD I JUST BYE NEW SPRINGS FOR MY OLD FORKS?)
    PRICE £215 IS THIS PIRCE OK?[​IMG]
    2.put a kundo chrome exhaust on a mate got me for cheap
    3.doppler air filter
    [​IMG][​IMG][​IMG]
    OK ..i think thats everything for now
    as i need this done in like a month for work
    NOW FOR YOUR HELP PLEASE
    you see the above doppler air filter..WELL it has 3 air intakes at the back
    1 open when you get it and you acn open another or all 3 i read it somewhere but cnt remember where
    anyhay look at pic of it at the back youll see what i mean
    so its making me think if i have only 1 aitr hole open would i need to rejet?
    what you lot thin standard jet is 82.5 i think
    but on some sites it says up ets buy 10-15 sizes so shall i get
    size 92 jet with 1 open air inlet on the doppler ir filter???
    also is the jet to be a 6mm or 5mm????? thread im guessing
    as on adrenilin site it doesnt have mikuni jets just dellorto 5mm and 6mm
    which one????
    looking forward to your help guys :punk:
  2. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    if you realy want to have a bit of fun, invest in a malossi 172 kit, there about 200quid for a air cooled typhoon. trust me it'll bring a smile to ur face :pimp:
  3. Paradox
    Paradox New Member
    maybe in the future
    but if i stick that on
    what else would need changeing?
    gears,, rejet higher
    and maybe oilpump set a lil bit higher to add a bit more oil
    for now could you or any1 read my bassic setup?
    AND most IMPORTANTLY ABOUT THE AIR FILTER, ITS LIKE A NEW TYPE, I THINK, NO
    AIR COMES IN AT THE FRONT!! ITS THE BACK AND YOU CAN HAVE 1..2..OR 3 OPEN AIRINLETS
    JET HELP PLEASE PEEPS
  4. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    ive never used that air filter so i cant help u realy but i cant imagine it beeing much differnt than any other open filter, tbh its not going to make much of a differnce on a stock engine. id start at around a 96 main jet and work down. with a 172 all ud need to do is upjet again and it will run ;)
  5. RojAEROX
    RojAEROX New Member
    theres a project section on the forum mate...
  6. Paradox
    Paradox New Member
    daym i was told to put it in here yesterday
    is their a way i can move it?
    its only really a jet setting question i was hopeing to get a reply for by today as i want to make the order asap
    and does it matter what make the jet is aslong as its the same size thread..i dnt think it would?
  7. Paradox
    Paradox New Member
    hmmm i hate you
    you got me thinking about a 172 kit now
    errrrrrrrrrrrrrrrrrrrrrr
    so a 92 would proberly be right on my setup then?
    any1 else read my thingy and have a answer
    i need to know this soooooo bad
    ALSO I KNOW IT WANT MAKE MUCH A DIFFERENCE TS JUST I CNT STAND THE STANDARD BIG FAT AIRBOX LOL
  8. alexsr70
    alexsr70 New Member
    erm what makes you want that air filter??
    go for a k&n or malossi one, tried and tested mate
    and bout 98-105 for them bt probs bout 90-95 on the doppler air filter
    Bore kits are the way forward mate
  9. Paradox
    Paradox New Member
    READ ABOVE MA8
    also Thanks so 92 is seeming a good size so far
    PS IS A MIKUNI TYPHOON 125 CARB MAIN JET 5MM OR 6MM THREAD
    also where did you lot learn all about how to do this stuff
    as i know if i find how i wouldl be able to as well
    thans o far
    PS IS THEM SHOCKS IM GOING TO BUY A GOOD PRICE OR OVERPRICED??
  10. alexsr70
    alexsr70 New Member
    jet is 6mm on the mikuni - ditch it for a dellorto tho...
    forks are expensive thats it lol, can get standards or even malossis too for between 150-350.
    experience is the main learning curve, i for one am a bike mechanic. did the courses done the practical etc.
    it dont say why you want the filter it just says blah blah please help jet my bike im too lazy or sumin like that lool, i really really wouldnt recomend it btw.
    but ye 92 sounds right but you do realise you will have to play around with transmission setup AND jetting.
  11. Paradox
    Paradox New Member
    92 sounds right but you do realise you will have to play around with transmission setup AND jetting???
    huh im changeing the main jet for 92?
    nah im not lazy ma8
    ive done alot to is in a quick time if you aske me
    although not moding just the ehole process of taken to bites to check for things and treating the fram etc
    and i just want to change the exhaust and filter
    as the piaggio 1nse make me want to be sick when i look at them
    ALSO YOU SAY...can get standards or even malossis too for between 150-350. huh i thought doppler would be better than standard as everyone with a typhoon includeing me has probs with stock front forks ..might be ba luck though
    anyway i thought mallossi front forks are like£400?
    is £215 for the fron dopplers to much
    whats the best place to buy parts like i need from to make sure im not overpaying
    THANKS FOR YOUR HELP MATE
    :pimp:
  12. rideorcollide
    rideorcollide Active Member
    TYPH 172
    about the airfilter
    theyre good m8, ive got one on my bike and it works like an airbox..doesnt make ur bike lazy.
    and buy a box of jets theyre about ten pound
    kl
  13. Paradox
    Paradox New Member
    that what i was thinking thats why i wanted it due to the design
    is similar to a standard box
    do you think i should still go up 10 sizes with the jet (82 go up to 92) with just 1 hole at the back open?
  14. rideorcollide
    TYPH 172
    yh you still need to upjet.. dont know how many sizes though, so buy a few or a box
  15. Paradox
    Paradox New Member
    daym thats the only thing i need o learn about the carb
    setting it up properly
    cause who ever had the bike before me fooked
    with the airmix screw and the throttle cable at carb & throttle end
    you got a link so i can quickly read and learn about it
    maybe even a place to learn everything about scooter building fixing moding etc....
    as im new to this stuff
  16. Biggie
    Biggie New Member
    No one can give u a specific size so stop askin.
    its trial and error..doit yourself and find out, if you realy are interested in your scoot then try
    i have one of them filters on my 172 with all 3 holes open and it works like a airbox but revs freely.
    and change ur pic..u scary muva fuckerr :rofl:
  17. Paradox
    Paradox New Member
    lmfao
    yp scary (crazy contacts in)
    and ok so i just keep changeing them untill it feels right?
    but ho wwould i know when its correct
    ps WHAT YOU MEAN BY IT REVS FREELY?
  18. typh70
    typh70 New Member
    you cant have a correct jet as such
    you have to try different jets drive the bike and see what ones
    feels the best in your opinion.
  19. Paradox
    Paradox New Member
    ok thanks
    i thought peolple would be able to work out
    which 1 would need useing by what was fitted to the engine somehow
    ..anyway seems not so ill do it your way
    thanks
    jets ordered :)
  20. Dec
    Dec Active Member
    nothing ugm
    mate read minors carb guide this will give you enough of an idea to know 'when its right' ;)
