My Polini Set Up
Discussion in 'The Workshop' started by CA Zip tuning, Apr 16, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    Gonna get this set up for my Zip, what do you think ?
    Polini sport 70s bore
    Polini Variator Kit, High Speed-
    Evolution 3 Polini 2G Adjustable Race Clutch
    Polini Kevlar Drive Belt -
    Polini gear up kit
    Yasuni R
    Malossi 21 mm race carb
    What do you think and how fast do you think it will go ?
  2. oliwest
    oliwest Member
    aerox road legal pit
    You getting a new crank?
  3. CA Zip tuning
    do i need one ? :confused:
  4. Stig
    Stig Well-Known Member
    EXUP1000
    Thats basically similar to what we were running but no gear up kit and std crank and I clocked my son at 70 (with satnav) if that helps
  5. CA Zip tuning
    Thanks mate, yh thats the speed i wana go 70, ill soon be getting money from my insurers so ill have about 5000 to spend :p
  6. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    if i was you id ditch the gear up kit and get new crank
  7. CA Zip tuning
    yh i might i dont really need a gear up with a low end kit like the sport do i ?
  8. Duggiedan
    Piaggio Zip
    i personally wouldnt get gear up, ive been told by a friend who is experienced with this stuff the gears pull at different times everytime
  9. CA Zip tuning
    ok crank it is then
  10. CA Zip tuning
    Apparently I should only get the crank if i intend to do over 60 e.g 65 70, so i cant say im not tempted
  11. ramo
    ramo GoldMember
    You will be lucky to touch anything over 60 on a polini anyway tbh. crank isnt completely necessary for that kit
  12. CA Zip tuning
    LOL what are you saying polini is shit ?
  13. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Look on the pedparts blog at the sport kit test, the stage6 is way better for top speed and acceleration and doesn't need a gear up.m
    Duggiedan likes this.
  14. Duggiedan
    Piaggio Zip
    btw you should have posted this thread in the general scooter discussions
  15. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    Look at the pedparts blog, the stage 6 kit maintains it peak power longer so it doesn't need a gear up kit. The trade off is the crank which will need to be changed as the higher power is deliverd at higher revs. My Aerox is fitted with a top racing (doppler) crank which is rated to 15000 revs and is more than capable.
  16. CA Zip tuning
    I no duggedian
  17. ramo
    ramo GoldMember
    nah not shit but it wasn't ever meant to be very powerful etc ;)
  18. CA Zip tuning
    So u reckon stage 6 racing then ?
  19. ramo
    ramo GoldMember
    Unless you're specifically after a cast iron kit. Naturally theres pros and cons for both.
    The sport pro is decent value aswell.
  20. Edgar
    Edgar Active Member
    why not polini corsa?
