My piaggio zip won’t idle and struggles to start
Discussion in 'General Scooter Discussion' started by reece crabb, Nov 14, 2017.
  1. reece crabb
    reece crabb New Member
    Hi I need help with my piaggio zip 2t I have a Malosi 70cc bore kit on it but the problem is my bike won’t idle I have fiddled with the air and fuel screws which does not make a difference I have also tried changing the idle jet and cleaning the main jet which also doesn’t change a thing and my bike still doesn’t idle and struggles to start every time I ride it it’s 50/50 chance of it siezing on me as I can’t tell if the air and fuel screws are correct and the bike doesn’t idle no matter what. I have also tried changing my choke and cleaning the carb which yet again does not change anything
    Can Somone please help me as this is one of my only ways of getting to college and back
  2. daveNRGdt
    daveNRGdt Member
    Has it ever run correctly since you have had the 70 kit fitted and what size main jet have you got?
  3. scubabiker
    Crank seals?
    Intake leak?
    Dead reeds?
  4. reece crabb
    It used to run fine I don’t understand and I have 105 jets
  5. reece crabb
    I’ll have a look and let you know
    scubabiker likes this.
  6. scubabiker
    And how is the compression?
  7. scubabiker
    But a bike will idle even if the main jet is completely missing...
  8. reece crabb
    Compression is completely fine
  9. scubabiker
    How much?
  10. Stevep
    sports exhaust?
    Open filter?
    More details on the setup please................
  11. daveNRGdt
    daveNRGdt Member
    What state is the spark plug in? It must be running really rich with a 105 main jet
  12. reece crabb
    It’s got leo Vince zx pipe
    Open air filter
    Not quite sure what rollers as that’s how I bought it
  13. scubabiker
    Put an airbox on it...
    But what was your compression at?
  14. reece crabb
    One of the reeds were slightly shredded somehow but luckily I had a spare which now it started first kick after but still doesn’t idle was trying to fiddle with the air n fuel screws but had no luck 334D2843-A618-42C8-BC94-47C81E2F206D.jpeg
  15. reece crabb
