my piaggio typhoon malossi 172
Discussion in 'Pictures' started by TyphoonLagoon, Apr 13, 2009.
  1. TyphoonLagoon
    TyphoonLagoon New Member
    My piaggio typhoon 172cc, few scratchs and the panels could do with putting back on i took them of to try to clean it, runs sweet and the front wheel just power wheeies :msn1: never had a malossi 172cc before brakes are really good, and everything works on the bike :cool: was first registered december 2000
    just needs a new throttle grip and its blowing at the exhaust. also like i said to re put on some of the panels that i cant put back on!! :wallbash:
    not bad for what i payed :)
  2. 2stroke-power
    2stroke-power Active Member
    on 1-wheel
    looking nice .get a pm 52 lol
  3. TyphoonLagoon
    no i hate pm lol
  4. FirE
    FirE New Member
    172 oyster card beep
    and so you should
  5. MiNoR cOnFuSiOn
    it has a runner pipe, good enough for now. avoid pm like the plague LOL
    raere to see a stock looking typh 125 these days... keep it up
  6. TyphoonLagoon
    yep going to keep it looking standard :) not doing anything else to it a 172 is quick enough for me atm :cool: also any ideas how to spray the exhaust black? do i just buy that high temp paint from halfrauds and spray it on? obvioulsy sand down the exhaust abit first?
  7. monty9120
    monty9120 Active Member
    Vespa gts300
    take the exhaust off. rub all the surface rust off. mask up the heat shield. give it loads of coats. then put it back on
  8. Sw1fT
    Sw1fT Active Member
    200SX S13
    put it back on when its still wet (or atleast try) and get the bike running, will bake the paint on nicely
  9. FirE
    FirE New Member
    use the heat resistant paint (soz to point out the obvious but you some people....)
