gutted for you bud i know how that feels it happened to me if you remeber not long back got about 25-30 miles out of a new piston i fitted then just cut out when i took it apart found one of the circlips had failed and ripped the piston and barrel to bits. were did you get the parts from bud ? the place i got mine replaced the piston and sent me a new barrel which is all boxed up as spare cos im running the malossi kit now
Happened to me before. I always end up turning the circlips a few time in their slots now to ensure they are in place correctly, not like it makes a difference but it does help keep my mind at peace
they was in right, we like checked everything 5 times. Spent more time calculating things than building it :L Got it from pedparts, Ohwell. Life goes on. Racing MKII here I come.
Dont give up on it! Even though the amount of money youve spent on it you couldve bought an insured a car itll be worth it when you zooom past little 1 litres hha
Yeah, got it off a friend haha, swapped a fresh yasuni r for it, just painted it black, cylinder will be here later today result!!
Mate on the stub of the stage 6 rep, they come in to two peices if im right? how did you file the bit off to become flat? if that makes sence? theres two stubs on has the bit sticking out and one dosnt lol did you spot weld it after?
One on the left is of a Yasuni c16 and it's not a rep For standard piaggio cylinders the one on the right is perfect. due to it having the oval on the cylinder. performs a better seal. But on my new cylinder that's been removed so going to use c16 stub to make more power
And Zipspeed I have one vid of it down meads. The rest of the vids you don't want me putting up I got pictures to go up. Just not yet
