my nipples are knackered
Discussion in 'The Workshop' started by polini118, Feb 13, 2008.
  1. polini118
    polini118 New Member
    heres a tip for bleeding brakes when your bleed nipple is siezed, rounded, or snapped off,and you have to ...replace the brake hose, for example. ... swap old hose for new one, take off master cyl. reservior cap and fill with clean brake fluid, then very ,very slowly pull the brake lever,and let it out again,about 20 times.you will notice tiny bubbles coming from the bottom of the resorvior, that means its all good so far. leave it a few minutes then pump the brake again 20 times. repeat this until you get good feel to your brakes.if you are working on your front brake, it helps to have your ped on its main stand and have the handlebars pointing left, back brake point the bars to the right,so the air bubbles come up easier. brakes are very important !! if you are not sure how to work on them, leave it to someone who does.
  2. wobbly_trials
    i wondered what the hell this was about, was waiting for the opputunity to tell you we didn't want to know about your bedroom habits.
    yeah that method works quite well, used it myself.
