My Aerox project ( i need your help )
Discussion in 'Scooter Projects' started by Cjkt, Feb 16, 2011.
  1. aeroxrob
    aeroxrob New Member
    if you havent run the barrel and rings in already then yes but there the only things you run in :) you will notice how much of a beast it will be then you will want a bigger carb :) im gonna get a 70 when i get the cash
  2. Cjkt
    Cjkt Member
    Aerox
    I have already run the barrel in and nice :)
  3. aerox-kid
    aerox-kid Member
    How's it goin with the 17.5 carb mate?
  4. Cjkt
    Cjkt Member
    Aerox
    Havent fitted it yet mate had to order a manual choke adapter so i can put my stage 6 choke straight on
  5. Cjkt
    Cjkt Member
    Aerox
    Right got my 17.5 mm carb on today and started to fiddle round with the jets :)
    Will get a video of it running when i have it running perfectly asap and then will be the end of this project :(
  6. Cjkt
    Cjkt Member
    Aerox
    Today i parked my ped up on my mates patio and when i wheeled it off my exhaust hit the patio and cracked :banghead: o_O
    So now i need to buy a new exhaust for it I was thinking a yasuni R?
    If you have one for sale Pm me please ?
    What exhaust would you recommend for my set up?
  7. Cjkt
    Cjkt Member
    Aerox
    Okay so i got the exhaust welded instead and heres a over view video of the bike the quality is shit but thats because i had to use some crappy phone as mine broke sorry!
  8. Jonnymarrw00t
    Piaggio Zip 05 plate
    Can you actually see those lights at night ?? (the blue l.e.d's ?) Nice bike bro.
  9. Cjkt
    Cjkt Member
    Aerox
    Yeah but i dont put them on when riding lol :)
  10. Cjkt
    Cjkt Member
    Aerox
    Right i know this project is slowly dying but, I had noticed that my exhaust when i first started it the bike would fly and then later on it would start to run slower. Turns out the stage 6 pro replica isn't a really good exhaust for my set up and it has been known to have a inconsistent power band which from personal use I can back up and definitely agree. So i am saving up and buying a Yasuni R fully de-restricted for my bike I also have a secondary gear up kit to shove on it then I will get it all finally dyno tuned so it runs perfectly :D
  11. aerox1995
    aerox1995 Member
    How much for the stage 6 ??
  12. Cjkt
    Cjkt Member
    Aerox
    Make me a offer cos i got to sort out some for my yasuni R :D ;)
  13. MiNoR cOnFuSiOn
    the only thing that can cause inconsistancey in performance is ether a poor quality can or a poorly desighned pipe. ie, the pipe is "telling" the engine to warm up (yes the pipe has alot of control as to the temperature the engine runs at) hence the longer you ride it the hotter and hotter it gets. this is easily cured mind. if its the can, replace it, if its not the can then shorten the can and if need be weld in a larger diameter stinger (u shaped section at the end of the exhaust)
    are you SURE its the pipe and not a cooling issue (worn waterpump/broken thermostat) as its the first ive heard about these pipes (then again, i dont use them, so wouldent have done any research) id say its more likely a cooling/jetting issue causing poor/inconsistant perfoprmance through excess heat
  14. lshigham
    lshigham Member
    I wouldn't have said it's the pipe, it should be fine. It's almost identical but non road legal twin the Pro cope's fine with a Stage6 racing, peaking at a healthy 12-12500rpm
  15. BenN23
    BenN23 New Member
    Aerox 70cc
    Peng! Evo kits are so nice
  16. danielbarton94
    danielbarton94 New Member
    i saw you on about a gear up kit , ive got one of them in my ped and its a win or lose situation , because top end im lots fast but acceleration im lots slower :( ( 70 polini kit should even me out :) )
  17. Cjkt
    Cjkt Member
    Aerox
    Sorry for the delay i didnt see any of these replys!! Well i rung up ped parts as they have been extremely helpful before and they said that the exhaust on 70's doesn't have a consistent power band which i have seemed to experience as said, to get further information i called pedstop and they said they do not stock these pipes anymore as of the poor powerband etc...
    I dont know really what im going to do i have been doing spark plug checks regularly and its running fine? Are there any other checks i could do?
    Also a little thing i am looking at a 2006 gilera runner tomorrow which if i get will be a further project!!! :D Thanks for all the compliments and responses !!!!! :cheers:
  18. Canning1337
    Canning1337 Scooter Tuner
    Yamaha Aerox 50
    Wow, that is really nice buddy! How did you fit that headlight surround trim? Because I'm thinking of buying it but I'm really confused as to how you fit it? Adhesive? Tape? Let me know, 'cause it looks lovely!
    -Good job bro, nice bike!
  19. Cjkt
    Cjkt Member
    Aerox
    Thanks alot!
    And no to fit it you take the front panel off and then remove the light and then it just slides on over the top and then you screw back in :) Easy as pie ;)
  20. Cjkt
    Cjkt Member
    Aerox
    Just a quickie,,, I am ordering a yasuni R tommorow finally ahah :)
