ok i hade a 180 bore on an 125 lump and it wert to bad on petrol but i put a 172 kit on it and it is drinking the petrol wot should use more petrol a 172 or a 180
180 gears and 13g roller 25 ml carb scopian pipe but i think i might no y its drinking petrol its got a leaking float bowl
A 172 has harsher port timings than a 180 barrel so the 172 is using more fuel and air. and i told youu that float bowl would rub throughhhh lol
your a spastic lol it was pissin out wif petrol the other day and i said get a new float bowl and take tha mudgaurd off which is rubbin against it.
put the carb in but rotate it slightly to around 1 o clock.. wont rub as much and a sponge will help. too much and it will rub on the side of the casing.
