motoforce racing
Discussion in 'General Scooter Discussion' started by chriscam09, Jan 14, 2009.
  1. chriscam09
    chriscam09 New Member
    hi, just wondering what everyone thinks of the motoforce racing 70cc kit. got it on my runner at the moment.
    chris
  2. Dec
    Dec Active Member
    nothing ugm
    same as the pm xtech kit.
    but still rather have the kit with motoforce on the box :rofl:
    good gains for the price imo.
  3. mhr-typhoon
    mhr-typhoon New Member
    seems to be a good kit 4 of my mates have them one has had it for 8 months now and still going like it was new
  4. waxhead
    waxhead Member
    I have one on my aerox
    I modified the porting and flowed the cases
    its hauls for what it is
    It will lift the wheel off the line
    if you have a look in scooter projects you can see it
    I figure it has about 15-16 hp
  5. MiNoR cOnFuSiOn
    right, not a bad cylinder but remember it is made in china so will be a little sloppy.. not sure how good the pistons are ether (wax?)
    as for the pm tunning kit.. LOL its the same thing, with some dirt casting in the side.. oh a diff box and costs like 40 quid more.
    if your gonna get one, go on the euro sites and order an ACTUALL motorforce cylinder.. dont have to deal with pm doing the usual m@its for race use, we dont do returns on cylinders, you fitted it wrong) when it fails.. where as from a proper supplier you get some leway if you can show you have a clkue and it still lasted 5 mins.
    in all honesty you can get power from cheap kits.. the real diff is the material its cast from and how well finnished it is, most cheaper kits are NOT hand finnished and quite rough cast. spend out on a decent kit and you wont have to fuck about wiht it
  6. waxhead
    waxhead Member
    It seems to be a nice kit
    the piston is not like other kits i have seen
    Its actually very well made
    I think its actually high quality china
    You know you can actually get china to make some quality stuff if you ask them
    Most people seem to just get them to make cheap shit
    The cylinder is actually a very good casting and it seem to be made like a mhr rep
    with slightly more timing
    the cylinder needs to have the aux exhaust ports opened up as they curl back in
    I would have no issue with using one of these again at this stage its been awesome
  7. chriscam09
    I agree completely. I have had it on for a few weekks now and its still running perfect. Revs throught the roof. You can get maby 14hp out of the box however ive ported the cylinder and botom end and have got 18.2. the port timings and the actual layout of the ports is very similar to the evo 2. the exhaust port is a lot smaller than it should be tho.
    yeah the piston is strange, but seems to be of a good quality.
    chris
  8. MiNoR cOnFuSiOn
    18.2? who did this....
    oh and why ask if you know the answer? should just recomend it to people surewly not ask there opinion of somthing you already have.. seems a littrle pointless to me (not bein funny) s
  9. chriscam09
    i herd it got a bad reputation for quality. Just wanted to know peoples general opinions about it. Didnt mean to cause any trouble.
  10. waxhead
    waxhead Member
    you got 18.2 on the dyno
    cool
    can i see the print out and your spec sheet
    i would love to see how it makes its power and where
    it would help me set mine up alot
    thanks
  11. chriscam09
    hey, i dnt have to spec sheet, but i can tell you that it made most power at 12800 rpm. what setup are you running on the cylinder? :)
    chris
  12. waxhead
    waxhead Member
    wow 12800 is high
    i am runing a
    city 16
    v-force reed
    21mm delorto
    case porting
    inner rotor ignition
    bgm full circle crank
  13. waxhead
    waxhead Member
    whats your setup
  14. typh70
    typh70 New Member
    i had a pm kit good power and brilliant while it lasted,
    i went through 2 in about 5 months
  15. chriscam09
    25mm carb
    case porting
    cylinder ported
    full stage 6 intake
    e13 filter
    mallossi overange
    polini clutch
    useing a yazuni z exhaust for everyday use, but dyno runs are with c21.
    chris
  16. waxhead
    waxhead Member
    What does it rev to on the z pipe
    What ignition are you running
