hey i am trying to set my rollers up on my yasuni c16, i currently have 4.5gram and 4.8. With both rollers when i set off the bike will go but not pick up revs fast for about 10-15 seconds and then the power kicks in, do i need to get stronger clutch springs?? thanks for any help
i have also put a line with a marker pen on the variator face and the belt is not going all the way to the top, i still have the standard contra spring in could it be this?
put torwue spring from a gilera runner in ( difference is runner has shorter spring) just because i was bored, sets off alot better with the runner spring but still not perfect
I see your only in bradford, You should get it setup on a dyno unless you plan on doing more to it soon. PSN in batley do dyno. Will be around £60 for best setup u can have i think. Or just keep messing with jets,rollers,springs untill it seems at its best.
think it just needs some tougher cluth springs and the right torque spring, could anyone suggest a torque spring for me (one they are using on a yasuni c16 with similar setup)
