mot'ing a scooter
Discussion in 'General Scooter Discussion' started by southweezy19, Aug 20, 2010.
  1. southweezy19
    yamaha neos!!
    hi guys jus a quick question as i have never mot'd a bike before can u tell me the things iv got to check to make sure it would go through thnx in advance safe
  2. nathan93
    Gilera Ice
    check your front forks is there oil on the forks
    is there visible tread on your tires you only need it to be visible on a scooter
    are your breaks good they need to be firm and should work when you pull the lever
    lights if it is fitted with lights they all need to work
    is there any play in the steering put it on its stand and see f you can move the forks about other than turn them
    wheels should only turn not be wobbly
    your exhaust shouldn't be too loud mot'd mine and have got an advisory on how loud it is
    there is probably more but thats what i can remmember off the top of my head
    on a 50 you dont need a speedo to pass mot
  3. jakey2482
    jakey2482 New Member
    also check engine bushes, all bearings ect
  4. southweezy19
    yamaha neos!!
    cheers for that m8 much appritiated, john
  5. Gilly-93
    Gilly-93 Member
    Aprilia Sr70
    bugger all mate up our end,buy em a cheeseburger and they pass owt :whistle:
  6. southweezy19
    yamaha neos!!
    lol maccy ds on the way to mot then 60p hamburger lmao
  7. bertie
    bertie Active Member
    '93 Skipper LX125
    You dont need to check over everything, thats the idea of an mot somebody does it for you. Just check all the lights work, brakes work well and tyre tread.
    The headstock bearings are a regular fail, but they do take a beat-in so its worth having them tightened or replaced yearly.
  8. southweezy19
    yamaha neos!!
    yh i know the point of it is for someone to check it for me i jus wanted to know what to check so that it doesn just fail wen i put it in. now i know what to check then i can fix the problems before the mot then itll prob pass ya get me safe for the reply tho ill be sure to see if it needs tightening or replacin m8
