MOT in the morning *Updated*
Discussion in 'General Scooter Discussion' started by Scott_LFC, Nov 3, 2011.
  1. Scott_LFC
    Scott_LFC Mucking Fuddle
    Lightspeed 2 125cc
    So i have my bike booked in for MOT tomorrow, any last little bits i should check.?
  2. OllieTGBR50X
    OllieTGBR50X Member
    TGB R50X
    Re: MOT in the morning
    i read that you need a reflector on the back above/below/on licence plate
    check tyres arent bald
    thats all i heard haha. read up about the reflector not sure if its for bigger bikes/scooters
  3. Scott_LFC
    Lightspeed 2 125cc
    When i say 'Bike' i mean scooter lol.
    The front tire is looking like it 'could' do with replacing within the next few months theres tread there but not much of it but theres enough to put your finger between if that makes sence, im guessing maybe 1.5mm of tread? (that should be 'ok' shouldnt it?)
  4. brettfield999
    brettfield999 Member
    Typhoon 172
  5. Scott_LFC
    Lightspeed 2 125cc
    I should be fine then. Its a Moped (49cc)
    Off to the MOT station now. (Fingers crossed)
  6. Scott_LFC
    Lightspeed 2 125cc
    Home from MOT bike failed..
    - Front disc pads below 1.5mm
    Everything else was fine, and no advisorys!
    So hes got me some EBC pads coming and they will be here monday morning, Are the front pads easy to change over? anybody know of a tut on how to change them?
  7. northrider
    northrider Member
    there easy to change you just remove the caliper from the forks and if you look at the calliper like a metal rod will be holding the pads there will be a pin on the end of the rod thing remove that then the rod remove old brake pads and put the new ones in they might take a little time to wear in
  8. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    be careful though, with some peoples bikes when they change the pads they need to bleed the brakes also
