Pressing the ignition switch, no noise, no movement, not starting. I havent got a kick start. IDK if my battery is dead or not, but I charged for like 24+ hours about 3 days ago. Earth wire is cool, idk tbh what is going on. I just put my new polini belt, my new polini variator, it the front pulley just seems to be so stiff and the belt so tight like. i'm just pissed of now man, i swear like it rains when i go outside to fix it, then when I go inside it fucking sunshines.
if theres no noise check the starter relay and the wiring to the back of the starter switch. why has your bike not got a kickstart?
I borrowed it to a friend so he could get home, because his somethign wore away or some bullocks, and i didnt really needed at the time, which was a big mistake, seeing as the fucker swapped the bike. Is the starter relay the cog right beside the front pulley? Wtf, ignore that, LOL, and i'm suppose to be an apprentice electrician. Where is the starter relay though?
on a gilera its below the front of the steat bucket (can get there via the battery inspection pannel) should be 2 big reds a black and a green
Thanks, gonna have to check it tomorrow, fucking pissing it down. :rant: See if I do come on fri ye, would you do both engines, or was you planning just to do j's? And if you're planning to do both, what do I need to get/bring?
will have to be afternoon/evening friday ye. can do both. 3 ish hours to do the pair if there in good nick/no horible supprises
