more nrg troubles - Idles but wont pull away <UPDATE>
Discussion in 'The Workshop' started by Lukash, Jun 24, 2008.
  1. Lukash
    Lukash Member
    SR125
    Right so my nrg is finally running again but it wont pull away. When its on the center stand the wheel does spin when i open the throttle but no where near as fast as it should.
    am i right in thinking this is to do with the clutch?
    i changed clutch springs while it wasnt working so im guessing i did something wrong when installing them :emb:
    any ideas?
    Thanks
  2. Lukash
    Lukash Member
    SR125
    bump
    really need to get my scoot going!
  3. wheelieboy
    wheelieboy New Member
    have you tryed cleaning your airfilter??????????
  4. Lukash
    Lukash Member
    SR125
    yeh ive switched back to my standard airbox and cleaned it.
    dont see how that would effect the drive to the rear wheel tho?
  5. wheelieboy
    i had a little red yamaha jog off road bike
    and i took it off road and it got loads of shit in the airfilter
    wouldnt drive would only tick over
    and when its on the stand it would rev a little
    soo it just sounded like that!
  6. Lukash
    Lukash Member
    SR125
    hmm yeah that sounds almost exactly the same. Ill give it another good clean tomorrow, if that fails ill have a poke around the tranny and see if everything looks normal
  7. Lukash
    Lukash Member
    SR125
    Have cleaned the air filter but nothing changed.
    Got the tranny case off and everything looks normal to me :unsure:
    Im considering taking the plunge and ordering a whole new transmission set up as everyting is stock aside from rollers and springs. Would that be very beneficial or just a waste of money?
  8. Nitro-Rhys
    Nitro-Rhys Active Member
    all i can suggest is try again
  9. Dec
    Dec Active Member
    nothing ugm
    LMFAO :w00t: :w00t: :w00t:
    *stupidest quotes material*
  10. Lukash
    Lukash Member
    SR125
    Ok so i fitted a new contra spring and clutch today and there was a slight improvement, it actually pulls away now but only to like 5mph or less.
    I decided to switch back to my standard airbox too so ive down-jetted from an 85 to a 78 but have seen no noticable improvements.
    Checked the rollers too and they're in perfect condition.
    Im so confused, any ideas anyone?
