mk1 zip panel removal
Discussion in 'General Scooter Discussion' started by bulliporker, Dec 30, 2012.
  1. bulliporker
    bulliporker Member
    how is the best way to remove the front panel on a mk1 zip , do i have to disconnect the front caliper and drop down the forks or is it possible to remove the panel if i remove the front wheel and mudguard any tips appreciated
  2. Edgar
    Edgar Active Member
    i think forks need to come off mate its same on mk2 zip what i did is cut the panel behind the wheel so it can do on and off , worked for me
  3. Stig
    Stig Well-Known Member
    EXUP1000
    I toyed with the idea of unbolting the front panel, removing the wheel & caliper and then unbolting the front mudguard in the hope that I could rotate the panel and mudguard around each other to allow the panel to be coaxed off without damage or having to drop the forks. Being as I've not had to take the panel off again i've not had a chance to try the theory
