mixing fuel
Discussion in 'The Workshop' started by aerox crazy, Jun 29, 2010.
  1. aerox crazy
    aerox crazy New Member
    Hi ive got another aerox engine , and will be putting all my decent parts from one to another.The new engine doesnt have a oil mixer and my other engine i took it off.
    Ive been told i should premix it as im running
    70cc polini , 2 ring kit
    yasuni
    21 mm deltomor carb , black
    malssoi cdi
    malssoi clutch
    malssoi variator
    malssoi crank
    And other stuff.
    Any way , what do i pre mix it as, i can mix as i have to on my yz85.Or will it be ok to put the mixer back on ? .If i did put it back on , do i pre mix for the first tank?> :cheers:
  2. capri dave
    capri dave Active Member
    how much oil to add to the fuel when using pre-mix has been covered sooooo many times now :banghead:
    a lot of people add 20ml of oil to 1 litre of fuel which is 50:1....
    if you re-fit the auto lube system, which is what i think you mean by a mixer :confused:cratch:
    then you will need to bleed the system to remove any air :)
  3. aerox crazy
    Yea i mean the oil pump , sorry fella if its been covered i do try and look but thought as different parts ect .
    When you say bleeding do you mean the litle srew if so , could you give me a quick run down if you dnt mind . :good:
    Also would you use the oil pump or pre mix with my set up ? :cheers:
  4. capri dave
    I am a big fan of using pre-mix, and have done on my own scoot for about 18 months now :cheers:
    to bleed the oil pump: you undo the bleed screw and replace it once oil with no air bubbles starts flowing out :)
