Mine and My Friends Project
Discussion in 'Scooter Tuning' started by nick, Feb 25, 2008.
  1. nick
    nick New Member
    Hey Guys, In the near future me and my friend are going to be doing some engine work on our scoot(s)
    At the mo, my friends looking to buy an aerox, and I've got a minerlli air cooled engine to use, which ill drop into one of my frames.
    So in theory. we'll have two mineralli horizontal engines, one ac and one lc.
    We've decided on the setups were going to run, both almost the same, this is what we will be using, so please don't both reccomending us other kits etc thank you.
    Going for polini sport 70 kits (cast iron)
    21mm delloroto carbs
    new clutches
    polini speed control kit (mainly for belt and rollers, and also to replace old parts, not necessarily for performance)
    I know ill be keeping a standard derestricted exhaust on the a/c engine, and on the lc either a gianelli reverse or a laser x pro, also standard air boxes.
    Please can people reccomend jetting for each engine.
    Also when putting a crank in the freezer to harden it, how liong does it need to be in there for?
    Also is it worth porting your crank case to match the abrrels, giving a bit better air flow?
    Thanks
    updated
  2. chris14
    chris14 New Member
    no i will be using a sports exhaust either a gianelli reverse or laser x pro
  3. capri dave
    capri dave Active Member
    ok 1st its a Dellorto carb...
    2nd the rollers will be the only bit you wont use (they are always too heavy in the kits)
    3rd The main objective to putting the crank in the freezer is to shrink it...
    makes it easier to fit...especially if you heat the centre of the main bearings as well!!! ;)
  4. nick
    nick New Member
    1. whats wrong with dells
    2. how much too heavy will they be
    3. who said it made them stronger
  5. chris14
    chris14 New Member
    lmao
    im gona be runnin polini 70cc kit
    dellorto 21mm carb
    gianelli reverse
    get a set of rollers or two
    clutch springs
    thats about it i think
  6. nick
    nick New Member
    two sets of rollers, in a stanard variator, id like to see this
  7. BrummyBoy
    BrummyBoy New Member
    1. Dave picked up on the fact you spelt Dellorto wrong
    2. Its a case of trial and error with rollers, each rider is different weight etc, so roller weights will normally be different for each individual rider.
    3. WTF are you going on about?
  8. nick
    nick New Member
    ok ok.
    im light as hell ;) like 7 stone yeah ;)
    also, im sure i read freezing the crank etc, makes them go in easier but also makes them stronger :confused: on this forum/.
  9. capri dave
    yes you read right...but the primary reason is to freeze the crank to aid fitting...
    mine was in the freezer for about 3 weeks...but about a day would be enough ;)
  10. chris14
    chris14 New Member
    obviously wont get two sets of rollers in a variator
    i mean im gona buy a few sets to see what 1s work best for me
  11. nick
    nick New Member
    change of plan for the ac due to funds.
    getting a new vari and belt as mines preti nackered, and comes with 6g rollers, but ill buy some lighter
    getting a clutch, ive got clutch springs already which havnt been used.
    gona run a polini sport 70 probs, with standard carb, airbox and pipe, i was going to just rebuilt as a 50, but for £20 more i can get 70 so may aswel.
    please could anyone reccomend the size of a main jet id require for the standard carb and this 70kit, so basically it will be standard except 70kit pretty much.
    i know the standard jet is a 72 size, so theres your start point :)
    thanks
  12. nick
    nick New Member
    Price Plan.
    _________________
    70kit £62.95 Pm Tuning
    Rollers £4.50
    Jets £1.25 (x3)
    _________________
    Gasket set £6.99 Beedspeed
    Clutch £12.99
    Cranks bearings and seals £10.99
    Variator set £29.99
    ________________
    Total £132.16
    Gasket set may not be needed, i am buying it for the bottom end bits like the crankcase gasket, reedblock gasket, and the tranny cover gasket, do i really need these or can i just use sealant?
    Variator set comes with a kevlar belt. 3 jets to experiemnt with.
    Any advice?
  13. SR-STEF
    SR-STEF New Member
    looks liek u need to add vat to most of them prices.
    pm tunings prices dont include VAT and
    £12.99 for a clucth is stupidly cheap
  14. nick
    nick New Member
    ok so vats an extra £12.46.
    and thats just a clutch off beedspeed...what clutch would you reccomend? (its just to replace the currecnt one due to wear)
    pm sell a ''adjustable race clutch'' for like £20 but a RACE clutch for 20 is proberly worse than a stock for 13
  15. stephen_h
    stephen_h Member
    are you sure that the £12.99 isnt for a set of clutch spring and not a whole clutch. that price sounds way too cheap for a whole clutch have you got a link for the clutch?
  16. nick
    nick New Member
  17. haugh
    haugh New Member
  18. nick
    nick New Member
    ok, so basically id upjet by like 12% then work down, and if i use exhaust id add 10% and work down ;)
    do you have to change the oil supply feed?
    and is that clutch anygood, got to be better than one thats done 7000miles no?
    ta
  19. nick
    nick New Member
    Jettings – for 70 kit, (standard jet 72)
    5% - 76
    6% - 76
    7% - 77
    8% - 78
    9% - 78/79
    10% - 79
    11% - 80
    12% - 81
    13% - 81
    14% - 82
    15% - 83
    yeahh ;)
  20. nick
    nick New Member
    sso buy 78 79 81 ?
