Swedish MHR Ciao For a long time, Ive been fascinated by homemade bikes, so i decided to do my own. The frame is from a Piaggio Ciao and my goal is to put my Minarellicarter on the it. One of the headoptions for this project is that you should be able to take the carter of and switch it back to my SR50 Maybe you have seen my White/purple SR on under the "Perso scoots" BTW. I hope this counts 50% as a scooter, since i got the enginge. Malossi MHR Replica 70 Italkit Selletra Racing Yasuni Carrera 16 kevlar etc. etc. Keep urself updated: -LC from Aerox -Sandspray the frame -Frontsuspensioner from SR -Cut off unnecessery frameparts to win some extra kilos -Killswitch, Temp/RPM-counter -Build an subrame, to hold up the carter on the frame -The LC-cooler is on the bike -Reinforced the frame with stainless steel -Frame 100% modifyed and complete -New lagers for the front suspensioner -A final touch for the look !!TestRun!! The SR This is my SR where the carter comes from. When i want to drive it instead of the Ciao, i just take of the carter and adapt it on the SR. Cooler for the Malossi Cilinder. Sandsprayed frame The frontsuspensioner Had a look with the SRrims and it looks so hot! At the workstation Me and my budd Erik has been on the workstation and cutted like everything off. Wheres the fuckin ciao? Some small stuff to make it look hotter 27 dec The subframe itself is done, but I still need to welld it on the frame. The frame is for the moment very thin and weak, but I'm gonna reinforce it with stainless steel..! 28 dec The frame is for the moment only "pointwelled", if i need to adjust it or re-well it. After this im gonna well it all the way Reinforcements - 29 dec Intake *p0rn* The cooler is on the bike The frame was a little to much to the right, compared to the backwheel - like 10mm. So I moved it. Now it's perfect. Black drawing is how it's now. Suspension arms The Bikes frontpart is complete! Wonderful arms with my shiny rims. The reinforcements are in correct lenght now. The brake with some brand new Stage6 braking pads Go mat, efter en lång natt. 04:00 Woa, it starts to look like something. Look how nice it's welled! Wünderbar! The frame is complete. Nu börjar den se fet ut med alla motordelar! :0 Nightwork, 16:00 - 23:45 The "vespa" it self is done! cables, ignition och and the RPMcounter is installed. I had to work late to make everything okay. The only thing that needs to be done is the frontsuspension (as i said). Observe that some cables are just wired on. Im taking care of the look, after I've done a testrun to see that everything works as it should Looks great on me, well I am a small person, 168cm. hah
would be sick to ride , looks like alot of hard work has gone in to this , looks nice bruv keep up the good work
looks imense god i want one :w00t: you know your manifold on the sr engine take it that was oversized when it was on the sr until you changed it to the 1 for this crazy bike :drool:
Tnx alot guys I just want to make a testrun right now! Tomorrow me and my friend might get everything complete and maybe drive it. Fuel/oil, brakingfluid and coolingwater is the only thing i need
