Upgrade from a cast iron 70cc and it use run perfect but since I put in the kit and mvt did inner rotor it would only do 35km if that. Went thru a whole bunch of cvt settings testing 4g,4.5g,5,g5.5g with s6 medium torque spring, Polini 20kg and 30kg torque spring, and with the green, yellow, blue Polini clutch springs and it’s no better Setup: zip sp lc S6 racing mk2 Malossi rhq crank Mvt dd inner rotor 21mm Dellorto roost rs5
Have you still got the original stator to fit back on, to eliminate the inner rotor from your enquiries.
I tried the original stator and it’s still the same result it still feels like something is holding it back
So the problem was the oil seal that goes on the crank wasnt in all the way and it was leaking I pressed back in properly. might need a new one but I don’t see no damage so I will jus keep an eye on it.
glad you got it sorted Thats one that i doubt anyone would of thought of suggesting. with all the changes you had made i was certain it was going to be a set up problem.
