elo lads im runnin a DNA 50 and i use to have an MHR rep and that was rapid but from wat people have been sayin about them on here there not the best so wat kit MHR or MHR rep also wats the best performing exhaust to exploit the power cheers boys :tup:
reps are good if you use a proper exhaust... im not saying they are the best, or there isnt better...but youll deffo notice more power over something like a malossi/polini cast iron sport !! the problem is people run them with x-pro's and other cheapo sports pipes, because they realise a C16 or similar costs considerably more than the rep kit it self :tdwn:
so probably the best set up would be the MHR replica run in with say a c16 or c21? heard the MHR rep exhausts are pants wat bout pm 360? cheers
The MHR-rep pipe isnt meant to be all that really, and the PM 360 pipe is just another sports pipe... you want a pipe with a seperate stub, anything else will hold the rep kit back...a lot :nerd:
sorry to be a pain lol was jus wonderin i jus found out that the 70 malossi MHR racing bore kit can chuck out 20 - 21 bhp if tuned right is that more than the MHR rep if tuned perfect or dus the rep chuck out more im gona choose one of these two so leme no which is best cheers :tup:
well, ye it does, wiht the right pipe/carb/floed case setup perfetly... and even then it wont be any use on the road. will rebuild it weekly. rep's are cheaper, longer lasting lower power versions.
