MHR Kits
Discussion in 'Scooter Tuning' started by Storm, Oct 2, 2013.
  1. Storm
    Storm Member
    Nothing atm
    Hi there i was wandering if somebody could fill me in on the high end mhr tuning kits. I am talking about the single ring kits, what crank fits which kit, 86cc etc...
    Basically I would like to know if case work is required and if anyone can show me a good setup there running with good results.
    The reason for this is I'm thinking is it possible to pull 20hp from a zip sp without spending thousands.
  2. ramon777
    ramon777 The newkid on the block
    MBK Rocket
    for a mhr speed or cross 6T and 7T needs casemodding,
    A Speed can be used on minarelli with a standard 80mm crankshaft with normal stoke.
    a Cross version needs a 85mm crankshaft with normal stroke.
    A bigbore77ccm kit even needs casemodding, but fits on the 7T even with the crankshaft and can be driven with a normal 80mm crankshaft.
    a bigbore 86ccm needs casemodding, bigger stroke crankshaft with 85mm.
    and even requires a pen13 crankshaft if i'm right.
    ( can tell u soon more about the 86ccm bigbore, buddy of me bought this cilinder and i have to build it up and adjust it )
    To pull 20hp a stock untuned polini evo with the right parts can do that ;)
    Butt i say with the right parts, ignition, right exhaust, etcetcetc.
    A lot of testing with reedvalve's exhaust etcetcetc.
    and a lot of adjusting and changing parts.
