metal in casing
Discussion in 'The Workshop' started by h.hubbyy, Mar 3, 2012.
  1. h.hubbyy
    h.hubbyy Member
    JOG R
    how to properly clean out the bits of broken piston from crank case? on a speedfight 1
  2. revolution
    revolution Member
    split the cases and completely strip the engine, removing all the metal and shards and go along the cases with a magnet to get all the little shards, odds are there will be more damage than you first anticipated
  3. Sketchytom
    Sketchytom Roach
    Rally 50 you get me
    only real way is to strip
    although once i did fill a crankcase with parafin and shake about then empty a few times till i was satisfied. but i wasnt even sure anything was in there lol
  4. h.hubbyy
    h.hubbyy Member
    JOG R
    i have never split a case before , is it hard :confused: ?
  5. Jonnymarrw00t
    Piaggio Zip 05 plate
    Get someone to press it out for you. Don't do it yourself if you intend to use the crank again. You will need to replace the crank bearings aswell.
  6. Danaerox94
    Danaerox94 New Member
    With my rd125 I used a magnet to get big bits then filled with petrol and shock it around and drained a few times
