metal float bowl
Discussion in 'The Workshop' started by Leeroy, Jul 18, 2007.
  1. Leeroy
    Leeroy Member
    just got my metal float bowl, and theres an overflow nipple on the bottom with a long tube linking upwards it dosent look like this goes anywhere do you remove it?
    cheers
  2. MiNoR cOnFuSiOn
    if you cut an internal tube it will just leak out fuel as its the overflow (if the float sticks in the bowl the fuel flos through this instead of into your engine) so if you cut it it will just run out. the external nipple you can cut back flush if you wish
