anyone know where i can get a metal float boal from? need it for my 25mm. its not in the wanted section because i would like the sites for it. but if anyone DOES have one then lets talk :welcome:
here the float boal its 13.42 http://scooter-center.com/catalog/produ ... 137a413786 you also will have to buy drain bolt with it which is 4.03 http://scooter-center.com/catalog/produ ... 137a413786
The plastic ones rub and split all the time. Some manifolds help a little but if you're going over bumps and what not it will still hit the mud guard. There are plenty of people on here i know of with storys of splitting float bowls. My brother went through two before getting a metal one.
Im looking 28mm metal float bowl, Seeing as mine vibrates like a bitch, I tried soldering a oil tap into a carb before but the solder itself wouldn't stick!... Premix time.
