For less than 50km i change my nrg's speedo cable 3 times.. they cuts very fast :glare: i check the speedo drive with putting a little stick in it and turning the front wheel its turning ok.. the last time i put and grease.. with no result... i saw the speedo arrow hav one... like vibration .. moving when i drive.. and one other question for the rpm tacho... from the last time i have been changing my crank bearings and seals my rpm tacho dont work correctly.. it shows somethin between 500-1000rpm less than before? in all range of rpms .. ?
yep the all cables snapped.. like the original one.. but the original snapped on 10000 the new one snapped from 5 to 20kms .. my first two was from the local dealer, the last one from scootercenter.com ..
maybe the speedo drive on the front wheel is sticking, or your not routing the cable properly.... speedo cables need to be routed as straight as possible, any corners they turn have to be a long sweeping arc...
