Hello this is my first post im only 20 and not a handyman so i will do my best to explain.I bought a 98' mbk bws 50cc(2st) for my commute to school and work. the first problem was oil leaking under the oil reservoir sensor because i overfilled the tank.second time the gravity feed engine oil hose snapped out of the valve fitting and i tried to secure it with a cable tie. now even though the hose is secured from the tank to the valve behind the fan, oil is still splashing all over the carburetor and spark plug cover from around that area. what could be? badly fitted gasket or faulty valve maybe something where the piston creates to much pressure and sends the oil back or a crack somewhere..any advice is welcomed. sry for bad eng https://ibb.co/Qmchfbk https://ibb.co/hC8jPWj https://ibb.co/nrM0Qbq https://ibb.co/sv2SHVb https://ibb.co/G3W0nQt https://ibb.co/9Hd7k3x https://ibb.co/q01twhq https://ibb.co/9vssXfr
