maybe the ports are blocked???
Discussion in 'Newbie Scooter Tuning' started by Husky510, Jun 9, 2012.
  1. Husky510
    Husky510 Member
    I have done around 1000klms on a streetrace kit on my Aerox. Just though I would pull the cylinder off to check it all out... was running fine, just wanted to check it all out anyway.. rings etc...
    So I pulled the cylinder off and am not sure what to make of the findings.
    The piston is obviously still on the crank, so on the side of piston (facing up) it is all scored terribly, most on the skirt part of the piston... and so is the barrel.
    The other side of the piston is in perfect condition. So one is good, the other side is very average.
    Also when I took the head off. half of the combustion chamber is coked up/black.. the other half is a nice shiney chrome.
    so if you were to picture the barrel and piston together.. the scored part of the piston is the same side as the nice shiney chrome side of the head...
    The perfect side of the piston is the same side as the coked up/black side of the head...
    Also, I don't know if its related, but oil is leaking out the plug hole and there is a dried trail of oil down the front of the head...
    What should I make of all this???
  2. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Do you run premix or auto lube?
  3. Husky510
    Husky510 Member
    I am not running the factory oil bottle.. I premix 50:1
  4. FiddyRox
    That's odd, I would've thought the problem was caused by too much oil but if anything 50:1 isn't quite enough for your setup
  5. Husky510
    Husky510 Member
    really???? What ratiio should I be running..???. I read some people run 40:1... but I wasnt that game.. so i went to 50.
  6. FiddyRox
    I'd say 45:1, I run 50:1 on a 50cc (see the spec in my signature), and since the streetrace is quite high spec for a sport kit 45:1 would be safe
  7. Jonnymarrw00t
    Piaggio Zip 05 plate
    No no, 33:1. I had to run that with my polini sport, and my mid-race cylinder. Sounds like your bike was running lean.
  8. FiddyRox
    33:1 is way too much oil man, stock oil pump is 50:1
  9. Jonnymarrw00t
    Also, What carb/jet you using ? Check for airleaks while you're at it. And what plug do you use ?
  10. Husky510
    Husky510 Member
    So why would only one side be worn... and why only half the chamber be coked up??? :confused:
  11. Husky510
    Husky510 Member
    105 jet in a 19mm dellorto.... I use a br9es I think
  12. Jonnymarrw00t
    Open filter ?? Well just above the exhaust port it gets mega hot, the other side doesn't ? I'm not sure without looking myself, Thought you knew this stuff riding a husky ;)
  13. Husky510
    Husky510 Member
    haha!! My Husky is a 4 stroke... and I dont mess around with that motor!!! Dont need too!!! LOL!!
  14. Jonnymarrw00t
    Lmao, Two stroke is more fun, Even though on a track a 4t is easier... Prick to start when hot though :L Get some pics of the bore up ?
  15. FiddyRox
    They have hot start ;D
    Would detonation cause the problems with the cylinder?
  16. Husky510
    Husky510 Member
    I decided while it was apart to port the exhaust port on the streetrace.
    It now struggles to get up my hill. going up my hill it sits on 7,000rpm... on the flat when it hits 8,000rpm it takes quick as normal. its pretty dead up until 8,000rpm now. I dropped the rollers in weight but no difference so eliminated that.
    Before the porting I was running a 50 pilot jet with mixture screw turned OUT 4 times. The more I turn it IN the slighty better it gets (deosn't break down as much at 6-7,000rpm) but still not going up the hill. Just bogs down. my carb is a 19mm dellorto. Is turning it in riching it up??? or leaning it out?? And because I ported it, is it wanting more fuel??? HELP!!!
  17. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    On most carbs turning in the mixture screw richens the mix,
  18. Husky510
    Husky510 Member
    ok so it must want a bigger pilot.... bigger than 50??? thats big!!!
  19. Jonnymarrw00t
    What main jet are you using....
  20. Husky510
    Husky510 Member
    105 size main jet
