hey having some trouble with the malossi wing clutch bell, when i fully tighten the nut that holds it on it grips hold of the clutch causing it to turn the engine over when you push the scooter or tun back wheel, is there supposed to be spacer or something or do you need the malossi clutch to work with it
did you remove the spacer from behind the clutch assembely atall? could well have pushed the bearings and spacer further back than it should be. deffinatly in need of some pics for this one as it sounds like your plain fitting an incorrect part
it works fine with the standard one on but the malossi one sits on fine untill you start tightening it then its like the clutch is engaged. and ye will get a lil video of me tightening it up tonight thanks lads
right got a lil video of it for you to look at but it wont let me upload it because its mp4, could one of you pm me you email and ill send you a video thanks
I've had a look but it doesn't really show anything. Was more looking for pictures of the clutch and the inside of the bell.
thanks terro, will take pictures of the clutch and inside the clutch bell and post them it is defanitly for this engine as i checked the number on the part (7711207)
