just fitted a malossi multivar to my standard piaggio de restricted zip and changed the rollers from 7.5 to 6 gram now it wont pull away unless you rev the hell out of it should i have left the standard spring in instead of the uprated white one what came with the kit
you only need to fit the spring if your running a mid/high end 70 to help prevent the drive belt from slipping, if fitted you need to go even lighter on the rollers. Because your still running a 50cc cylinder I wouldn't bother fitting the spring
you can drive the multivar without the springs, only adjust the weight of rollers and it should be fine
