Malossi Rollers
Discussion in 'The Workshop' started by CA Zip tuning, Mar 21, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    which rollers should i get as you may already know i have 5.5s in currently but my accleration is shit and its not smooth 15 mph - 40 im fine. cheers
  2. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Try 4.5's. Might be worth checking your rear Pulley out too.
    I have stage6 rollers, havent worn in 500 miles so far. They come with a little pack of special grease too, helps the smoothness and helps them last.
  3. Liam
    Liam New Member
    Aerox 100cc
    If you have fitted a sports exhaust without changing your clutch springs then that could be the reason it's slow at take off do the revs jump up when you hit 15mph? if so you should consider getting stiffer clutch springs.
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    You need stronger springs. 5.5's are about right.
