Malossi/Deloretto 22mm Carb For Aerox/Neos 100cc
Discussion in 'Maxiscooter Tuning' started by u33db, Jan 19, 2011.
  1. u33db
    u33db Member
    Several Bikes
    Hi,
    I'm in the process of fitting this carb to my Aerox 100 but am having a problem.
    The carb seems to have 3 inlets;
    - 1 large silver inlet on the side.
    - 1 small silver inlet on the next side.
    - 1 tiny brass inlet on the opposing side of the large silver inlet.
    Now i'm pretty sure the largest silver inlet is for fuel and the brass one is for oil (and i've connected them up as such) but i don't know what the other silver inlet is for...i have no pipes and the original tk carb only had these 2 connections.
    Does anyone have any ideas as the malossi instructions are less than clear?
    Thanks in advance!
    u33db
  2. u33db
    u33db Member
    Several Bikes
    Its a PHVB is that helps anyone?
  3. u33db
    u33db Member
    Several Bikes
    Some pics of the 3 inlets;
    The big inlet for fuel???
    The 2 other ones - brass one is obviously for oil but what about the other?
    Malossi install booklet just says to connect the 2 "fuel and lubricating" pipes???
  4. u33db
    u33db Member
    Several Bikes
    Ooops - i think the 3rd one is for a vacume line that connects to the tap.
    I'll double check tonight and if so apologies for the stupid thread - i'm assembling the engine on the bench and the bike is under a ton of rubbish atm so didn't think to check!
  5. eddo241
    eddo241 Member
    NEOS
    smaller of the fuel pipes goes on that one
  6. Jonnymarrw00t
    Piaggio Zip 05 plate
    Other one is return if i'm right.
  7. lshigham
    lshigham Member
    You are correct on all counts, they are fuel, oil and vacuum.
  8. RelentlessDan
    RelentlessDan New Member
    that makes you sound as if you were just testing us ;)
