Fitted a set of malossi carbon reeds to zip today, only thing is that when you look down the open end of the reedcage you can see a sliver of daylight at the tip of one petal. The reeds snap back okay when opened, just that there is always a spot where it doesnt seal completely t rest. Is this okay? or should I fit a different set. There were 3 thicknesses in the packet. One of the 0.4mm reeds is visibly bent, one of the 0.25mm reeds doesnt seal completely at the tip and of the thinnest reeds which I am currently using one is showing signs of deteoriation at the end.......
