malossi belt, which way.
Discussion in 'The Workshop' started by seancullen, Apr 2, 2010.
  1. seancullen
    seancullen Member
    et4 125,px80,dna50
    got a malossi belt for the et2 but its lacking an arrow for direction of travel, can it go on either way?
  2. adz452
    adz452 Member
    Vespa T5
    i faced mine so when you read malossi from the crankcase its facing towards you not into the crankcase i dont see why they dont put arrows on them though -.-
  3. bertie
    bertie Active Member
    '93 Skipper LX125
    That sucks, Im glad I got a Polini belt because they do have the arrows :)
    But my guess would be the same as above, have the writing facing you.
  4. MiNoR cOnFuSiOn
    it only matters once the belt is in the bike... you should run them in the same direction always. theres just as much pressure at the top of the variator as there is on the bottom onf the clutch. these belts are not directional (there bi directional construction) nothing lines up in one direction inside the belts so ye, use them as you have. dont turn them round..
    but ye as above, ethe rso you read malossi or follow whatever arrows are on there. just so you know wich way you HAD it in. if it matterd malossi would mark them.
