malossi 172 ac
Discussion in 'Maxiscooter Tuning' started by 125TypHXR, Jun 8, 2010.
  1. 125TypHXR
    125TypHXR Member
    im buying a 172 kit this week from scooter center , but i need to know if i need to
    buy ne thing extra to fit the kit or all that i need come's with it.thanks
  2. MiNoR cOnFuSiOn
    make sure your belt/rollers/front pulley/variator sliders and oil belt (if applicable) are in good condition, otherwise you get everything.... oh, buy a few plugs and a couple jets to be on the safe side, the kit comes wiht the gasgets and a set of reeds
  3. seanwhite06
    seanwhite06 New Member
    runner 172, zx6r
    id order a new small end bearing aswell if i was you! kit doesnt come with them, always think they should!
  4. 125TypHXR
    125TypHXR Member
    yer thats what i was thinking didnt see it in the pic on scooter center , but had a change of plan going to get the kit from baz on here with the pm gear up aswell, but gonna do a order from scooter center for a 180 belt ,180 variator ,blue clutch springs,malossi str8 inlet mani dont know what carb to get tho ? 25mm or 28mm? phpb or phbl and some jets.
  5. MiNoR cOnFuSiOn
    ye of course...... my bad, been a while since i bought one. deffo a must buy item
  6. 125TypHXR
    125TypHXR Member
    orderd a new gasket set and small end bearing ;) , just got a delly 26mm phph fs and need a bit of help setting it up , what size are the main jets for phph range? the set up will be 172 kit 26mm phph carb with malossi open e5 filter and pm gear up kit rest of the bike is standard.
