Hi, I'm still thinking about sticking an aerox 50 motor in my minarelli vertical powered bw 50. Thing is there next to no aerox 50s on ebay at the moment. There are however a fair few neos 50 engines. Can i fit a aerox 50 cylinder to a neos crank case to effectively "make" an aerox engine (minus the rear disc brake). Obviously i'd need to run an electric water pump (unless the aerox water pump will bolt to the neos engine) but i'm ok with that. Can it be done and is it "plug and play" (i.e. no machining of crank cases)? Thanks in advance!
you can get a neos 2t engine put a wc top end on and then get a mechanical pump for a aerox and bolt it on as it works off the flywheel its all plug and play shit with minarellis i have no idea of fitting them but i remember them sitting at a gay angle in a pic i seen of it done
