long stroke crank
Discussion in 'The Workshop' started by scottnrg, Aug 29, 2008.
  1. scottnrg
    scottnrg New Member
    was thinking about buying a long stroke crank for gilera runner 125 but was not sure how much setting up there is for one of these cranks or can you just fit the spacer and it will be ok and that makes it a 183 can any one help cheers
  2. connor
    connor Active Member
    i also would like to know as my friend is realy set on doing this but is not to sure what is diffrent from a 125 crank ect.?
  3. MiNoR cOnFuSiOn
    well, the conrod and stroke are longer so the top and bottom of the port's are in the wrong place.. also the degree at wich they open and close is wrong. without correction there a bit lazy.. once you correct the ports there MONSTERS altho ring life is reduced from the higher piston speed.
  4. scottnrg
    scottnrg New Member
    crank
    so i could just fit the crank with the spacer but wouldnt be that good. to correct it would the bore need porting cheers
  5. MiNoR cOnFuSiOn
    yep.. needs correction to all the hights. can run without but why use a long stroke crank and stock timings? :confused: tbh i sudgest people only get a long stroke if your porting the barrel anyway thus killing 2 birds with one stone.
  6. scottnrg
    scottnrg New Member
    crank
    does the bore need alot of porting to work with the long stroke crank and can you minor port a bore to work with the crank and if so how much do you charge cheers
  7. MiNoR cOnFuSiOn
    simple bottom correction is 50.. with hight raise and some reprofiling of the exhaust port/shape i usually charge 150 and this never disapoints. its a pain to do tho as you have to mark up bdc on the barrel wall once youve set squish...
  8. scottnrg
    scottnrg New Member
    crank
    would that mean i would have to send you my hole engine to do the porting cheers
  9. MiNoR cOnFuSiOn
    nah, just build it.. then take the head off. spin the piston to bdc then run a pen round the top of the piston.. theres fractions of a mm in it really and it can be done without you doing this but its guesswork. from that i can grind the bottoms and tops to within 0.1mm tollarance to your exact stroke/squish setting ;)
  10. scottnrg
    scottnrg New Member
    crank
    ok cheers minor i have not yet built the engine yet but am now defo thinking about the long stroke crank an what one do you think is best the bgm 55 or the pm tuning long stroke cheers you mite be seeing my bore soon if i get the cash
  11. alex_1966
    alex_1966 New Member
    there both the same crank arnt they ?
