Locked Up Back Wheel
Discussion in 'The Workshop' started by ICEY CRAIG, Feb 9, 2008.
  1. ICEY CRAIG
    ICEY CRAIG New Member
    my back wheel has locked up i cant move it unless i put good force onto it. i took the tranny case off and everything looks ok the belts on properly. i had a polini spped control kit put on the other day. but still its just locked up any ideas?
  2. frainey
    frainey New Member
    Brakes seized? oO
  3. wobbly_trials
    sounds like a clutch pad has broken up
  4. ICEY CRAIG
    i got a rear drum brake, but i dnt think its siezed. as for the clutch pad when i took it a part to fit the new variator it had alot of meat left onit.
  5. alexsr70
    alexsr70 New Member
    ye but it could have broken up since then, unless you take the rear pulley assembly apart then you won't no whats wrong with it.
  6. ICEY CRAIG
    ok but how does it brake up isit just over time or is there something causing it
  7. alexsr70
    alexsr70 New Member
    take it apart and have a look, could of caught and just ripped off
