list please
Discussion in 'General Scooter Discussion' started by Nova, Jun 16, 2007.
  1. Nova
    Nova New Member
    can i have a list of bits n bobs i will need for the conversion for my speedfight to a 125/172
    i need a
    Engine, Aprilia SR125 A/C
    Adaptor kit, from scooter-centre
    Rear wheel
    Wiring loom
    Air filter
    Carb
    anything else i need?
  2. wobbly_trials
    CDI
    Exhaust
    Shock??
    Brake cable
    best bet is to buy a typh or SR as a donor bike. to be honest, i would just ride an R, handle much better than a speedfight and imo look better.
  3. Nova
    Nova New Member
    reckon i should buy a cheap SR or typh then?
    i have a speedfight already, engine is knackered, so i want to stick in a 125 engine
  4. Sw1fT
    Sw1fT Active Member
    200SX S13
    your gonna need an sr shock like wobbly said, and then have to weld a mount higher up on the frame
  5. wobbly_trials
    personally i would flog the speedfight and get a typh or SR, but if you want to go ahead with the conversion then an accident damaged SR or typh would be perfect. even a runner would work, you could put an AC top end on it and have a disc rear brake.
  6. Nova
    Nova New Member
    but the adaptor kit you get, you get this thing to use for the shock on the speedy, so it should be ok
  7. Sw1fT
    Sw1fT Active Member
    200SX S13
    yeh but it puts the engine at a weird angle, personally i think its better to weld a mount on instead of use the kit, just my preference
  8. Nova
    Nova New Member
    yer i agree it makes it look at a weird angle... but meh ill see when i come round to it
  9. MiNoR cOnFuSiOn
    a new hole can be drilled in the adaptor and a chunk ground off if hight is an issue. remember these kits are ment for 50 engines so probably arnt strong enuff for a 125 so keep a close eye out for fatigue/stress fractures/cracks on evetry bit of the mount weekly atleast
  10. Nova
    Nova New Member
    cheers for that minor, its all just planning at the moment. so i get it right dont wanna rush into it and fuck it up
  11. capri dave
    capri dave Active Member
    funny enough ive got a speedfight sat in my shed in need of an engine..
    its nearly time for me to get motivated on it :w00t:
