light problem
Discussion in 'The Workshop' started by moansss, Sep 12, 2008.
  1. moansss
    moansss Member
    i got a little problem with my ice 125, the thing is the lights only work when i hold in the brake, i think it might be something to do with me trying to wire up switch gears but as soon as i pull the brake in the lights work perfectly except the flash. the horn and indicators work fine. just the main light dont. any one know what it could be??
    only wired up the left hand switch gear. and wasnt to sure if i done the high/low beam one right.
    thanks
  2. RojAEROX
    RojAEROX New Member
    if i understand what u mean coreectly then one of the light filaments may nave gone. there is two in your rear light. 1 is the light and the other iss your brake light
  3. Aerox-lad
    Aerox-lad New Member
    fuse may be blown or out of place. check that buddy. :D
  4. foxy-roxy
    foxy-roxy New Member
    try some fresh bulbs or check the connections if there loose or somefin
  5. moansss
    moansss Member
    bulbs and fuses are fine. the headlight only works when i hold the brake in, if you thought i was only talking about the rear light.
  6. one7twoboi
    one7twoboi New Member
    checked your earth?
    Have you had to wire the actualli clips together for the switchgear? sounds like you may have wired a colour to the wrong one. But check your earth, all connections aswell, follow the wires back,all of them untill you can find a fault, if no faults are visible then its time to dig deeper.
    But im pretty sure it is a loom problem mate
  7. moansss
    moansss Member
    havent checked it but the earths was ok when i put it all back together
  8. 2stroke-power
    2stroke-power Active Member
    on 1-wheel
    yr
    had this problem be with a coverstion wen u pull rakes in the front light went on u need 2 strip your bike my shore every wire is in the right place something u mut hav pluged in wrong
  9. moansss
    moansss Member
    well im going to take the bike apart tomorrow to try sort it out.
    anyone know what it could be or what to look for?
    ben
  10. one7twoboi
    The circuit must be broken(not literally) but the light only comes on when the circuit is completed(when the brake light switch is activated by pulling in the leaver)
    so just strip it and make sure everything is where is should be.
    are u sure it aint a fucked loom?
  11. moansss
    moansss Member
    well the head light aint working at all now :msn1: and my new front indys dont work :( just payed £10 for them to not work. looks like everythings coming off the bike tomorrow. maybe even a little spray :pimp:
  12. one7twoboi
    make sure ur battery is fully charged and working. Check the regulator for a burt or burning smell, check all fuses are in there and correct ones are there and also ur relays. can onli be something minor
  13. moansss
    moansss Member
    the first regulater i had burnt out. so i got a new one and lights was working with the brake on lol. do you think it could of burnt out the new one for some reason?
  14. RojAEROX
    RojAEROX New Member
    it might have done. check it again. do you check all the earths and that already?
  15. MiNoR cOnFuSiOn
    deffo an earth/rec problem...
  16. moansss
    moansss Member
    ill check the reg tomorrow but wouldnt that cause the indy's to stop working or am i being retarded?
    the earths seem fine to me :wtf:
  17. one7twoboi
    Naaa it would ben, trust me. Thats how my 125 started. No indys, no lights, then the fucka wouldnt start. Check everything tomorow an see wat comes up ;)
  18. MiNoR cOnFuSiOn
    usual cause for light failure is a dodgy connection on the oil tank (ye sounds funny)
  19. moansss
    moansss Member
    well today i was going to look at the bike after i got back from the compound and it wasnt starting :wtf: so i took the ht lead to the frame to see if it sparked and it only sparks sometimes i thing it could be dodgy hd lead or coil. i dont know ????
    some one help me with my new problem pleasee :)
  20. MiNoR cOnFuSiOn
    new problems are old probs gertting worse.. how about check everything electrical then messa bout running the thing.
