Hi all I have just recently. Purchased a lexmoto vienna 50cc engine runs beautifully. the only problem is the front wheel is punched right back. Haw would i go about fixing it. Would I need to just replace the yoke and forks. Or just one. And do anybody no if any diffrent front ends would fit on this bike thanks any help would be amazing.
It could be one of 3 things that's bent. Forks Yoke/steering pin thing Or frame You will probably find any Chinese scooter front end will fit, either right on or with a little modifying. Another thing to watch out for is the front wheel spindle could be bent.
Iv had the forks off don't look the bent at all. So must me the yolk. /frame. Is the only way to no if the yoke is bent is to take it out. The only replacement I can find is with the size. With the attached pic can't seem to find any with that sizes. So haw can I modify one any help would be verry much appreciated. I will upload a pic of the size yoke I need. And a pic of the dammed bike
Drop the forks out, steering stem is usually in the same plane as fork legs, try Chinese motorcycle parts online. If it's the frame then throw it away !
This is the only bend I can find. The forks look straingt. With one oil seal gone. No bends or crimped paint. / flaky... And no other signs of damage. So would this be the only peice to replace. If so do enyone no wear I can get a replacement please any help would be much appreciated thanks
