leo vince tt noisey
Discussion in 'General Scooter Discussion' started by craigdmjv, Feb 21, 2012.
  1. craigdmjv
    1984 Yamaha Salient
    i have a leo vince tt on my nrg and by god is it noisey compared to my other bike lol is this normal
  2. revolution
    revolution Member
    yes sports exhausts generally are noisier than standard pipes, running the standard air box will make it a bit quieter if your currently using an open filter
  3. craigdmjv
    1984 Yamaha Salient
    no its standard filter
  4. Edgar
    Edgar Active Member
    it might have a little hole somewhere or its not tighten up near the cylinder, or the stuff inside the endcan is gone. but tts are noisy i had it on 70cc aprilia :)
  5. phil.s
    phil.s Active Member
    ive just taken my zx pipe of my nrg (the same nrg as you ) as it was so stupidly loud. i thought the wadding might need repacking but a brand new can came up for sale so i bought that and it was no better
  6. craigdmjv
    1984 Yamaha Salient
    they re extremely raspy aint they heres vid
  7. phil.s
    yeh they are the zx is more motocross sound to it but i have a tt pipe ive just never used it and the hole down the centre of the tt end can is double that of the zx so maybe thats why yours is a deeper sound to mine but yours bud has that bwaaang bwaang sound which is a tell tale sign of being a bit lean what size jet you running
  8. craigdmjv
    1984 Yamaha Salient
    i have no idea mate tbh i want to know the standard size to check then if i need to i can go bigger
  9. phil.s
    standard is 53 i started with a 65 then went down to a 62 which most peaple use but i found it a bit rich so ended up with a 60 and it was spot on.
    you want a box a 6mm dellorto jets i got mine from ped parts (i think) a box of sizes from 52 to 72 was about £12.
    your not fitting a open filter are you ? and leave the brass plate in the carb intake
  10. craigdmjv
    1984 Yamaha Salient
    so if i fit a 60 it should be spot on then like yours
  11. craigdmjv
    1984 Yamaha Salient
  12. phil.s
    i wouldnt like to say budlike i say the tt and zx have a different size bore in the end can and different size expansion chambers which will give different back pressure and affect the mixture in a different way like i say your best of getting a box of jets and a new spark plug or 2 and start high and work back down or if there is a garage near you wich a dyno they dont charge much to jet/setup mopeds most ive ever paid on one was £15 and it was 2 fella's on it for an hour
  13. ramo
    ramo GoldMember
    Nrgs come jetted 56 as stock i think so 60 will more than likely be too lean
  14. roxy boy
    roxy boy Well-Known Member
    roxi
    were th fuck do u go thts well cheap ...cos it int psn cos cos that 60 plus parts
  15. phil.s
    they come stock with a 53 jet
  16. ramo
    ramo GoldMember
    Is it? Ive definitely seen a 56 jet that hadnt already been changed in an ac nrg carb...anythings possible with peds though i guess
  17. craigdmjv
    1984 Yamaha Salient
    im going to be blocking the oil inlet on the carb as im running it premix due to the oil tank leaking so ill have a lil look then
  18. ramo
    ramo GoldMember
    Dont you reckon premixing petrol is more of a pain in the arse than sorting the leak? :p
  19. phil.s
    pre mix is all good if you have a lc ped and running an expensive setup but on an air colled 50 id just buy a second hand tank of fleabay there only a ££££
  20. craigdmjv
    1984 Yamaha Salient
    oh ok it keeps leaking out where the filter joins the tank
