I want to change my back bulbs to LED can I just put in these http://www.scooter-center.com:80/sc...O:A_PIAGGIO_TPH125&category2=CAT:CAT_ELEKTRIK and a led relay and job done? Is that even the right size for a typh?
You'll need to buy a flasher relay to use the LED's, or use resistors. Take off the lens and see if it has the size imprinted on the bulb, and compare that with the bulb on the site. If not, then check the bike's manual.
thanks yeah i found out the size is ba15 so should be a easy fit. finding a 4 pin piaggio 125 led relay is turning out to be a pain in the arse though
So i have a Scan Pod from walmart..its a decoy LED alarm light...it has 2 wires, RED BLACK AND YELLOW. According to the instructions its POS Main power, Constant 12v. and ground...now i have a little switch box with 2 Double AA batteries inside...with a red and black wire comming out and im trying to get this to light up the LED but its not working...any ideas how i can get this light on without useing a 12V from my car...like u know how u light a light bulb up with a battery an some wire..something like that...thanks..anything will help --------------------- flexible led strip high density led strip 12v led light bars
just buy an led of the colour you want that runs on voltage as low as 4 x aa batteris equal too, then solder a switch in the middle, cant imagine why youd want a decoy alarm light do people even look for them by the way i have to highlight what you post too read it as it blends into the background
