Alright all, Bike seems be dripping fuel from drain screw on carb - overflow pipe? Have tightened this all the way up and it still leaks? :wtf: My fuel cap does not shut 100% as the barrels been jacked so im wondering if it isnt airlocked in the tank then it will piss out still? Complete guess on that one but thats the only thing i can think of. Suggestions?
i think its your bowl the bit on the bottom of the carb mine did the same still dose if i tilt it to its side stand it just leaks until the carb botto tank empties.
look in your bowl... i'm missing a little pin of sum sort.... and it leaks just a little may be the same for you?
:blink: :mod: :rules: :this: wtf.... dont ride wiht a leaking carb... its the float pin/shutoff valve. whip it apart and sort whatevers wrong. never ride with a leaking carb
