Hey, is the laser x pro e marked, and where is it restricted. is it worth buying the malossi airbox filter insert thing
ordered x pro and polini variator, might get the filter when i get the 17mm carb. any ideas on deretricting, need to know whether ill need a dremel
well you dont NEED a dremmel, i just rip the cones out with a screwdriver and pliers, file down the spot weld if theres anything left on pipe :rofl:
goty dremel anyway lol, was hassle derestricting my other pipe, so its the manifold then anyway, nice and simple hopefully ill have my clutch and tht so i can fuk around witit fri afternoon after my thoery test!
cheers bud iv jus got myself a carb of an aerox 100 (17mm tk) and its got standard jet in atm, rekon ill have to adjust it much, will have a polini 70 sport and laser x pro, dont know whether ill need to life needle up as its on a 70 from a 100 or what thanks
