Last bit of advice on parts before i put my order in to sm
Discussion in 'Maxiscooter Tuning' started by tip1, May 28, 2009.
  1. tip1
    tip1 New Member
    Hiya all.
    I am going to order some parts from scootermatix tomorrow, and would just like a little help on choosing between a few parts.
    I am 100% getting
    Polini Evo exhaust
    Malossi 172 kit
    Koso Clocks
    But i cant deicde between
    Malossi crank or
    BGM 52 mm crank
    BGM pwk 28mm carb or
    Delorto 25mm carb
    Malossi MHR Reedblock or
    Polini Evo Reedblock
    And i dont know if i should order a malossi cdi or not.
    Also has anyone used the arktek rear shockers ? ( the pnumatic ones ).
    If so any good ?
    Any opinions appreciated
    Many thanks
    Ricky
  2. MiNoR cOnFuSiOn
    u think WAY too much about this sort of thing.... you know the difference between the poolini and malossi reedblock? prittymuch fuck all, there all prittymuch the same as a stocker
    malossi crank = more expensive than the bgm 52 and the malosi isnt even completly stuffed so isnt really worth the dosh..
    pwk or phbl? its down to how your using the bike... is it a bike to ride about on for hours or is it a bike for a bit of fun?
  3. CU*TSPEED
    CU*TSPEED New Member
    whats sm?
  4. bait
    bait Active Member
    sm=scootermatrix
  5. tip1
    tip1 New Member
    Its a weekend toy minor, with the odd maybe hour long ride out.
  6. MiNoR cOnFuSiOn
    then pwk it is... just got one of the new stage 6 carbs (black rt pwk) and i gota say it is tidy as fuck.. sent a real keihin back for quality issues and got this instead. LOVELY looking/cut carb and they really have simplkified the setup of the thing.. instructions in the box are spot on also so should help anyone set one up.
  7. scottnrg
    scottnrg New Member
    sorry to go off topic but what is the website for the place you are ordering these parts from cheers
  8. tip1
    tip1 New Member
    Look in the introductions section for a post called " scootermatix is giving something back ".
    All the info is in there.
    Cheers
