Laggy take off
Discussion in 'The Workshop' started by Filip, Sep 23, 2014.
  1. Filip
    Filip Member
    My jog RR has suffered from this for quite a whole now, when I had my 50cc cylinder on it would build up when I pulled the throttle and then take off, now I've put a 70cc cylinder on and it's even worse it takes ages to build the revs up and then it just shoots off like mad, what is causing this anyone know?
  2. solorider
    solorider Member
    Longjia LJ50QT-K
    when you fitted the 70cc barrel you moved the powerband up, what you need to do is fit lighter rollers to get the engine revving higher when pulling off, you will need to experiment to get the right weight rollers.
  3. Filip
    Filip Member
    Rollers are perfect mate, it's the clutch springs I've figured, they're too soft
