Hey all, I purchased a gear up kit namely " primary transmission gear up kit Top Racing +17% 18/50 for Kymco, China 50 4-stroke" from top racing jasil, but it did not fit, I have a agility 16+ 50cc, but it's slightly confusing because some websites label it different nsmes, anyhow. Malossi do this kit https://www.malossistore.eu/NL/prim...16-rs-50-4t-euro-2-kl10b-6714189-kyag5016-M-P I was wondering is someone knows if it will fit, below are pictures of my current gearing system , thanks.
Don't waste money on anything, your Kymco will never be fast, just derestrict it and buy bigger when you can, this may sound bad advice but it is true ! You need more power to pull a gear kit, more cc's would help with std gearing.
Too late my slow ass kymco already has 52.40mm Bore and Head A9 Camshaft Racing crankshaft Irridium plug Racing high output coil Racing CDI 24mm carb 102# main jet 24mm smooth intake manifold Jetflow manifold spacer Unrestricted modded airbox Silent pro exhaust Malossi multivar 7g Dr pulleys Shortened boss Fly clutch and bell Torque control Torque driver upgrade 1500 spring Kevlar belt 17% Primary gear increase New hoses and breathers Fast flow filters Harder rear shock Custom vented rear brake shoes Upgraded kick start All new gaskets and seals Castrol power rs 4t oil 10/40w 80/90 Malossi sport gear oil Marsh, I do not want a bigger bike bro, it has to be this one because it' has a special color number plate that enables me to ride on bike paths, only 4 stroke 50cc limited to 25kmh are allowed this designation, so it has to be this bike I'm afraid, anyhow I wouldn't call it "slow",....unless I was comparing it to my R1
Oh are you in holland? Whats a vented brake shoe? Sounds like a pointless thing to me... I cant help you with the gear kit, only way is to buy one and see if it fits...
Yep Holland, the shoe has small holes drilled through it because a 50cc scooter needs temperature control on its pads haha, yeh I know the easy way to check is to buy it and see if it fits, but I already wasted time and money and effort opening up the gear case to fit the newgears j brought that don't fit.
Can you please share the end result? How is your top speed now? Did you found gear up kit for the kymco that fits?
