im after a kundo exhaust for the sr125, typhoon125 etc chrome, good condition and as cheap as possible i will more then likely just get a new one but if people have one going for less i may as well get it!
Beedspeed had one cheap. Was stained from being in the shop, but nothing y a bit of elbow grease can't fix. Kundo's Rapids are worse than stock though mate. Noise makers.
i had a kundo rapid on my speedfight....frickin loud and shite power!!! i ended up putting the std pipe back on....seemed faster like that, even with a 70 kit.... The kundo is hanging up in my shed to this very day....providing quality accomodation for spiders :w00t:
Thats because they are bad for the 50/70. The 125 is a completely different pipe and mine hasn't snapped yet either, sounds good and most of all with a bit of adaptation you can move the powerband from the mid range nearer to the top end pretty easily. And then they're fine... I'll post dyno results up of adaptations and moving the power when I get back (using the 125 bore and then the 172). Put it this way you won't need to buy another pipe every few weeks to replace the one you just snapped either if you get a kundo plus they're already chromed.
