kit or pipe ?
Discussion in 'Scooter Tuning' started by yamaha1, Apr 20, 2008.
  1. yamaha1
    yamaha1 New Member
    hi there guys ive looked over the forums alot and seen that you all think its best to start by fitting a 70cc kit rather than a pipe .. to start off with , i then thought surley the standard exhasut will restrict it and so will everything else
    and getting a kit will make it less reliable im looking at a polini iron and a laserx pro which would be best to go for first , oh and why , thanks again - tom
  2. kyle1b1
    go for the kit,
    going to give you more power per pound,
    is cheaper than the pipe.
    obviously will work better with the pipe.
    and a correctly fitted polini iron sport will be just as reliable as the standard bore.
  3. capri dave
    capri dave Active Member
    pipe on its own is for looks and sound (cosmetic performance)
    70 kit is for power (real performance)
    nuff said ???;)
  4. MiNoR cOnFuSiOn
    a pipe will never really make that much power over stock setup correct.y where as tyhe 70 kit odds more power, setup right the stock pipe works quite well, so you can ether strain the hell out ofyr engine for an extre 1bhp with a serious loss of life (stock barrels wernt made to rev) or you can double your power without anyone knowing and the engine live as long as poss
    best off going with both but grab the 70 kit first
