kickstart wont buge but engine isnt seized
Discussion in 'The Workshop' started by bait, Sep 10, 2009.
  1. bait
    bait Active Member
    ok so i put the kickstart cover on my engine and the kickstart is solid take the cover off again and the kickstart moves fine however the vari etc spins fine and the piston moves up and down nicely
    any ideas?
  2. MiNoR cOnFuSiOn
    Re: kickstart wont buge but engine isn't seized
    you have an old shape engine wiht a new shape bigger front pulley
  3. bait
    bait Active Member
    other way round new engine old pulley. still a problem?? will i need whole thing vari n all changed or can i just run it off the leccy start
    ps thanks for the quick reply
  4. MiNoR cOnFuSiOn
    ok, should clear.. id guess the spring is out of place holding the crescent gear out on the kickstartt cover meaning it clashes wiht the pulley.
  5. bait
    bait Active Member
    found the problem fuckin outer pulley aint on enough and its rubbing on the kickstart case
  6. bait
    bait Active Member
    this makes no sence now as outer pulley is as tight as it will go now it cant get any tighter its up against the spacer yet it still sounds like the outer pulley is rubbing agiainst the kickstart case when i move the kickstart
    is the nut on inside engines vari n front pullley wider then on the rollin nut engine?
    or maybe theres different washers or something just so i can rule that out as the problem
  7. MiNoR cOnFuSiOn
    check the spring.... it could be holding the kickstart gear oput ~(the big moon shaped one) common problem. the centre of the gear should be flush wiht the inside of the casing
  8. theheap
    theheap New Member
    i can't help :confused:cratch:
  9. bait
    bait Active Member
    glad you decided to tell me that lol :good:
  10. bait
    bait Active Member
    it all looks fine o_O and i even took apart my other kick case just to compare and they both look exact same
